Can I use the kit with present ECU?????
You might get more replies if you ask a specific question.Can I use the kit with present ECU?????
Normal ECU does not really have any issues reading from the cas at higher rpms. I have spoken to several Japanese tuners including Mine's and they have all said there is no need to external trigger kits when using a std remapped ecu or an F con pro.
