1 - 10 of 10 Posts
hi all
i have for sale a trust 9 row oil cooler kit.the only problem is its missing the relocation part,but this still can be used but fitting the sandwich plate to the block and oil filter to that.
im after £250 posted within the uk and £270 posted in the EU.
many thanks
leo
Often the sandwich plate has a thermostat, so you will have an in an staright out, then a diverter when the temp is say 80degrees to put the oil through the cooler.
Cheers,
i will check on the size tomorrow.10mm seems about right.
Pretty sure the Trust/GREX kits use AN10 size fittings. They are Earls fittings, so check thier website if you need any adaptors or different fittings, as the AN type fitting doesn't seem to be that common.
1 - 10 of 10 Posts
