Folks
One of my reversing sensors is broken and apparently I can't get an individual sensor replacement - I have to change the whole sensor setup with new version ?!
In the meantime I want to be able to turn off the beeping noise - it's now an alarm noise that basically says the sensors aren't working and it's driving me mad
Any idea how I can turn the noise off ?
Folks
Brian at Carkit Company used to sell a reverse beep defeater if that helps
Could take the fuse out. I don't know which one but presume it shows on the diagram on the cover of the inside footwell fuse block (by drivers feet)?
I did look for that but the fuse is not clearly (or clearly enough for me :unsure:) indicated on the fuse box cover
nor can I find what other fused item is most commonly associated with reversing/parking sensors
I guess I will keep looking
