1 - 7 of 7 Posts
I have taken off my R33GTR after about 4000miles as I want to go down the same route as my time attack car with my road car.
Kit includes Manifolds, Turbo's , Downpipes, wastegates and screamer pipes, Airfilters.
Turbo's are 3037 pro's both with new and slightly larger cores and the compressor housing replaced by Turbo dynamics August Last year
Car has hardly moved since, turbo's are mint and all other kit is working well, produced [email protected] (dyno sheet here) on my 2.8 motor at the peak but usually ran at wastegate pressure as it did nearly 600 @ wheels at the 1.1 bar . The Manifolds had a small crack in them which I am having repaired right now.
Looking for about £2500 for the lot
you do have to rev it to make it really go but it was still really drivable. The side by side graphs make it look alot steeper than it is as well. It had my sequential gearbox in as well at this time so it was a mad car for the road.:cool:
Ok to clarify this the turbos are originally HKS 3037 Pro BUT they had new cores fitted by Turbo dynamics and the front housings repaced with garret ones as the originals were damaged by the core failure.you can still see the Exhaust housings are original with HKS cast into them. I have taken a load of photo's of the turbo's and will add some of the manifolds when I get them back on the next day or two.
As they are devalued by the Garret Housing will take £2k for the kit.
Much less than that and I will just keep them as a spare set.
1 - 7 of 7 Posts
