I they have theremostat control valves then it wont cause a problem, two oil coolers with no stats will stop the oil reaching a sensible working temperature
The effectiveness depends on the size of the cooler and where it is in the air flow. look at it this way though, whats happening to the oil in the rear diff and gearbox while you are maintaining the temperature of the engine oil
UK spec had box and diff coolers under the back if that is what you are looking at
Pope
