is it possible to have twin t51r Kai bb or spl bb turbos? and has it ever been attempted at all?
Yes not being efficient due to drive train lose right? I know no car that can put the same power down to the ground as they put to the flywheel if that is what you are talking about...Im fine if I cant get 1500hp+ I just need enough to take down what ever steps up. I can have Crower custom make a 3.1L or 3.2L to my spec and that thing can handle serious power. Crower custom stroker kit the cheapest stroker kit I know that lets you have options. But I am not worried I just want to be a highway king, track demon and drag leader thats all I am trying to do....by not being effiecient i mean you have 2 big turbos and not the power they both produce. the 3.4L will run 1600bhp atf and more with nos. you are using a 3.1L and the most power you will get is 1200bhp so turbos that size are a waste but look good. if you have smaller turbos i.e what everyone else does you will prevent excess lag.
this ken henderson can only have the power that the turbos will flow( air/fuel) -1060bhp atf on standard 3240's.doesnt matter how big his engine is.
if you have a 3.4 supra with the twin T04Z you will get the 1400bhp atf but with bigger turbos you will get 1600 atf @ 3.0bar
when he means efficent he means the turbos and the setup.Yes not being efficient due to drive train lose right? I know no car that can put the same power down to the ground as they put to the flywheel if that is what you are talking about...Im fine if I cant get 1500hp+ I just need enough to take down what ever steps up. I can have Crower custom make a 3.1L or 3.2L to my spec and that thing can handle serious power. Crower custom stroker kit the cheapest stroker kit I know that lets you have options. But I am not worried I just want to be a highway king, track demon and drag leader thats all I am trying to do....
all at the same time. Even builders in Japan have 2 motors one for drag and one for time attack. They switch them as which races they are competeing against.highway king, track demon and drag leader
