1 - 20 of 21 Posts
Correct me if I´m wrong.... But hasn´t this picture been up before, and as I recall, someone found out it was fake....??????
Looks really cool though.....:D
well nissan made a "twin-charge" production micra in the eighties - so why not somebody else do a twin-charge rb26?
looks cool!
Looks nice but a few points.
Assuming the 2 inlets into the intercooler are the same 2 pipes coming off the turbo's.-
Where the piping exits the supercharger it just seems to end straight behing the intercooler piping, surely you should be able to see some kind of joint or bend? And it would need valves somewhere to stop the supercharger simply blowing it's air back out through the turbo's. Either that or piping going from outlet of supercharger into inlets of turbo's to blow through them.
Sorry I'm in a picky mood today!!
Following EJH#25
Cord, this is only a question so bare with me.....
Presuming that the 2 inlet pipes to the intercooler are seperate, and that the 'turbo' pipes are welded at point '1' (if that would be feasable or just too restrictive?) then the lower intercooler pipe would be purely for the supercharger - although it would be a 90 degree bend.
If '2' is an inline none return valve and is repeated (with different pressure ratings) for the lower pipe, would the system then work?
If that makes sense?
Did they ever get it working properly? This picture is three years old at least but I don't ever recall it actually working properly.
Definately looks strange. That appears to be a roots style supercharger that normally sits on top of the intake manifold and forces the air/fuel into the engine...how would this set-up work?:confused:
Banned
Doesnt matter where the charger sits, its just a screw style charger like most are.
And the fuel only travels through the charger if thats how the car has been set up, ie on old yank tanks running a big carb.
Only reason why this setup looks strange is the way its piped in, not a very good way of doing it, and unless it has some kind of 1-way valve setup i cant see, it wont work at all, and even then its a poo setup.
Following EJH#25
Steve,
Isn't there inline valves in the inlets to the intercooler.
As in number '2' in the pic above?
I must admit that I had understood that they couldn't get it to work properly on the road. Something to do with the mapping I'd thought?
As John says, it is at least 3 years ago that this first appeared, so if they had got it to work, I would have thought we might have herd a lot more about it by now!
Following EJH#25
SteveN said:
Matt- Possibly, but they need to be a 1way valve to seperate the turbos from the charger, and them ones look like they after that join.
Look at the pic on the wall in the background Steve - aint that 2 x 1 way valves stopping reverse flow?
Actually, welcome to TAS 2000! Time flies in repost land. LOL! :D
Unlike the example in this thread, I think there was a working twin charged setup at TAS 2006. Can anybody recall or confirm with pix?
Cya O!
1 - 20 of 21 Posts
