Hello,
I'm about to starting to put my rb26 back together (just waiting on two shims for valve clearances, that should be taken care of by tomorrow!!!). I received ARP headstuds that says to use thread sealant if the studs go into the waterjacket. When I removed the original head bolts, the front bolt on the intake side had a bit of rust on it (not much). So I was wondering if thread sealant was necessary or was the rust just a freak occurance?
Next question; do I need to put copper gasket spray anywhere, is it recommended I put some on the headgasket?
Thanks in advance,
Mitch
No and no
