I don't know if is just me, but I always seem to have a problem with tyre pressure.
Unfortunately I use my car every day for work, and end up picking up nails and other sharp material from time to time.
So far this year I have had 3 slow punctures and one leaking valve.
The problem is unless there is a dangerous dramatic blow out, (which luckily I haven't had yet), you never know until you see one of your tyre
looking a bit podgy. At this point I usually go to my local garage to pump it up only to find I have been driving on it for 2 weeks with 15 PSI in it.
I year or two ago I saw a gadget on the market that electronically monitored your tyre pressures and temperature while on the move. Limits can be set and it will alert you when pressure falls or temperature rises.
What a great idea I thought, ideal for track days.
Yesterday I was looking around the Demon Tweeks Web page and found it on special offer. And a very special offer it was, Reduced from 250 to
just 100 quid. Well this time I bought one. Its currently winging its way to me as I type.
So If you sometimes have deflation problems then this may also be a gadget for you. :smokin: :smokin:
You can find it on : www.demon-tweeks.co.uk
