Yellow warning light for low tyre pressures alert again. I know what the problem is but cant seem to fix it. Amy suggestions?
It first appeared this spring when the car had been in the garage for the winter so it had been sat for 8 weeks or so not driven. Front drivers side tyre pressure down to 16 psi. Took it to Kwik Fit because we thought it was slow puncture. It wasn't but corrosion around the inside of the rim causing a less than perfect surface to bond with tyre and thus letting air escape.
Guys took the tyre off, wire brushed it all down treated the corrosion, liberal application of soap and back on. Sorted.
Then a few weeks back the exact same problem on the rear drivers side. Same problem off to Kwik Fit diagnosed and fixed the same way. Wire brush etc.
Its happened again.
The wheels have recently been refurbed by a guy in York and look brilliant. Will new tyres fix this problem or am I going to have to fork out on new wheels? Cars a 59 plate.
Its happened again.
