If you wanted to remove a wheel, say for cleaning purposes, would the TPMS still work ok after re-fitting, or does it need a reset by a factory tool. I don;t want to think about removing mine to find that it then needs to go to a dealer to turn-off a warning light.
Also if the wheels were to be switched right to left to even out tyre wear, does the car need re-programming?
