What make of tyres do you use?
  • Goodyear
    Votes: 112 11.8%
  • Continental
    Votes: 32 3.4%
  • Toyo
    Votes: 185 19.5%
  • Pirelli
    Votes: 40 4.2%
  • Michelin
    Votes: 42 4.4%
  • Dunlop
    Votes: 67 7.1%
  • Bridgestone
    Votes: 197 20.7%
  • Avon
    Votes: 25 2.6%
  • Yokohama
    Votes: 104 10.9%
  • Falkens
    Votes: 146 15.4%
  • Total voters
    950
41 - 60 of 341 Posts
Tyre wear
My S02's have been on for about 4,000k now and have worn quite well apart from the front tyres on the outer shoulders .:( .I will swap the left to right front tyres after Bedford to maybe get a little more mileage out the fronts .:)
Tyre wear on these softer compounds will depend much more upon ones driving style . Peter drives very smoothly (and slower than most of us :p) so I would expect his tyres to last longer . It sounds to me Sammy that you must be a liitle rougher on your tyres ,like me ! Do you suffer alot from understeer ?
Understeer
hi paul - i didn't think that my driving style was especially hard and understeer has only been a problem on the one trackday, a moment or two before pretty major oversteer.. i suppose that what has surprised me is how quickly they have worn compared to the old Bridgstones on the back. If it was that track/drag day that alone obliterated my fronts, i'm curious as to why the rears survived it so well. I'll tap Mark's brain on saturday down at the Japs meeting,but will have to get my skates on soon after that, so any strong recommendations from 34 owners running on the stock wheels would be very welcome
cheers
Sharp to the bottom of the glass
Well spotted Mr P .:)
I heard the grass needs cutting . How can I resist ???????:D
Sammy .
It's my fronts that have been worn down but my rears are still in very good condition . Guess not too much oversteer action . Gonna have to see what I can do about that at Bedford .:D Why don't you try Falkens ? Shin and a couple of others have them on their cars and speak highly of them . The price makes them more attractive .
Falkens
cheers paul - i'll probably do that... attractive pricing will be a big selling point, especially since i'd be replacing all four tyres:eek:
tight squeeze..
i have had new fronts put on (Potenza RE040s, to match those on the back) and, unlike the S02s, on full lock they scrape against the wheel arch. I have spacers in which, as i say, didn't cause a problem before. Any ideas as to preventing this (apart from removing the spacers:) )?
sammy
Re: Bridgestones
sammy said:
Would love to carry on with SO3s but at that rate of wear it just isn't going to happen.
Hi Ian,
I thought you has SO3s on? Did you mean change to SO3s rather than carry on with SO3s? I couldn't understand how you could wreck a set of SO3s so quickly....
Are you saying that you had different tyres front and back?
Peter.
all confused
my mistake peter. The position was this -
1 had RE040s all round but the fronts needed changing
2 put S03s on the front, with a view to putting them on the back too, once they were worn out
3 as it happened the S03s just disintegrated within a couple of thousand miles, so i went back to RE040s on the basis that whilst they may tug around a bit (they definitely do), at least they last. I couldn't afford to risk S03s again just in case it wasn't a poor set and more a case of my strange driving style just not agreeing with them. The tyres are being checked and it may be that they were defective in some way.
sammy
Ian,
Don't whether having different compound/pattern tyres on either axle could lead to differing wear rates with it confusing the Attessa or not. I guess the testing may prove this.
Good luck.
Peter.
Deffo Yokohama AVS Sports for road, and I've a rare set of Yokohama AO38's for special occasions,
~DC
Proxes
I got a new set of Toyo Proxes T1-S about 2 weeks ago from Demon Tweeks for £130 a corner. They're bloody excellent... Thanks to all of you that recommeded them to me :)
Paul
Tyre Sizes
As the recommended 245/45/17 tyre size for the standard R33 9" wheel is not too common amongst tyre manufacturers, has anyone tried/ or can recommend, other widths/sizes that can be safely used?
Others on this tread have used Toyo and Falken to name but two, but I can't see 245/45/17 in their range.
Many thanks
Bridgestone S03 self destruction
Sammy
In what way did you B/stones disintegrate. I was just wondering if yours has gone the same way as mine. Just removed the wheels to give them a bit of scrub up and this is what i found. The Bridgestone engineer is inspecting them tomorrow will let you know on the outcome. Not the first case im told.
As for the wear factor 5k miles and me rears are done, maybe a little heavey footed in my GTS but expected a few more miles from them.
Itchy
