Hi guys, had the car at the bodyshop to do a front end respray to clear up the stone chips. While they had the bumper off, they turned the ignition on and moved the car and this seems to have activated the pedestrian safety system warning light on the dash (the bonnet pop up red warning light).
I plugged in the Ecutek cable and got 2 codes:
1. C1109 – ABS ECU, Air con etc
2. C1711 – TPMS
Re: the second code, I think this is unrelated and bad luck as when driving back I had a yellow "TPMS malfunction" warning and advised to "visit dealer". I checked the tyre pressure readings on screen and it seemed the left rear sensor was starred out like this "***" but the other 3 were ok. It then, seemed to fix itself and the warning went away.
When trying to clear these codes, I was unable to do so with the EcuTek cable. They both remain.
Any ideas??
Also, is it likely I'll need a new TPMS sensor if it is intermittently giving a fault or is this fixable in another way?
Thanks in advance.
2. C1711 – TPMS
Any ideas??
Thanks in advance.
