1 - 11 of 11 Posts
Who was doing the bolt kits for underfloor panel and diffuser?4
Sent from my SM-A920F using Tapatalk
I used to sell them but no longer do them. You can get the bolts etc off ebay, you need 30 X M6 at 20mm and 30 X M8 at 16mm plus 20 mm diam washers all made in A4 stainless which is marine grade stainless.
I've got enough left for a couple of sets, for £35 I'll send all that I have to you. I bought a 100 of each with washers when I did mine, the rest have just sat in the garage ever since, a4 stainless IIRC.
Simon
Can anyone tell me if these are countersunk etc? Just looking at ordering some off eBay and I can't check as my new GTR only arrives this week - trying to get ahead so to speak :chuckle:
Just normal bolts and washers work fine.
OEM are dog point but you'll struggle to find A4/316 like OEM.
It***8217;s shocking how quickly the bolts corrode, I had to smash some bolts out of a 2014 subframe.
Best bet guys is plenty of lube, if your running low then borrow the wife***8217;s. Good luck and I Hope there***8217;s an happing ending to the problem.
1 - 11 of 11 Posts
