121 - 140 of 238 Posts
Very interesting read and i look forward to the updates.
I used to see you out and about on the roads round little crosby
Discussion Starter #122
Are you the DMG driver based around The Serpentine?
Discussion Starter #124
No. I know the one you mean.
I did live in Ainsdale, now Great Altcar.
Ah that's okay then. The chap from The Serpentine ignores me and JohnnyG so your name would have been mud!
Another update, I've also ordered Litcho's upgraded oil cooler .
An interesting read
Is the quaife front diff a limited slip as per Nismo?
IMO Capricorn make some of the best pistons, I believe McLaren use them.
Does the bore hone remove all of the low friction bore coating?
Discussion Starter #126
An interesting read
Yep the Quaife is a limited slip diff.
No idea about the honing bit!
Discussion Starter #129
Really? Which bits buddy?
Litcho forged engine package, pistons/rods. Not necessarily alot more power, but rather for safety.
Was thinking throttle bodies and inlet manifold..800hp or thereabouts is plenty to be honest.
Front diff is a good idea to do now, little additional labour, and certainly makes a difference to fast road/track driving.
Discussion Starter #131
Boring stuff update...
Block back from Litchfields all honed
Crank, rods etc back from balancing
Oil pump rebuilt
Timing chain and cam covers back from powdercoating crinkle black
Block extensively cleaned, ready to be rebuilt this week (hopefully)
Discussion Starter #133
Tough crowd in 'ere!
Litcho's honing the block..
ARP main studs in situ
Mounted, cleaned and ready for reassembly...
Oil pump rebuilt
Oil pump rebuilt? Whats was wrong with it? Rebuild over getting a new one? My build is getting a new oil pump.
- Tomei Poncams, I've gone for HKS cams.. Gonna be interesting to see what it all sounds like, feels like once done.. Hoping to get mine back soon, acspeed are getting some miles on it, bedding in process before I get it back, with a low map to drive just over 450 miles then back (oil change etc), and another 450 before it can be full map let loose! Wooooooo
Discussion Starter #136
Any idea what your oem rods looked like ? ie were they bent
Build is looking good BTW
Rods were surprisingly in good nick, considering the track time my cra has had.
Blueprinted oil pump, not really refurbed in that sort of way.
ACSpeedtech like HKS so no surprise Andy chose their cams. Lower level cams are all actually quite similar in terms of IN/EX durations but HKS have macthed their cams to their turbos so wise to keep to the same.
Discussion Starter #138
How do you blueprint an oil pump?
Does that mean just taken apart inspected and put back together?
Ostensibly it varies from pump model to model but in the case of the R35's it means adjusting the meshing of the internal gear sets as there's some binding. There's also a slight catch of the inner gear on the input side that rubs on the casing apparently.
In effect it's about improving the smoothness of the internal parts to reduce wear, heat and stress.
As it happens my oil pump has been stripped and has seen better days so I'm having a new one fitted.
Discussion Starter #139 (Edited)
Another update...
Paul has been hard at work fitting the following..
- Engine back in with new everything (gaskets, oil pump, timing chains, bearings, etc etc etc)
- New intercooler (Litcho superstock)
- New intercooler pipework (Agency Power)
- Litchfield/Quaife LSD front diff
- Tial BOV (SD kit installed)
- Ported inlet manifold
- Larger turbo inlet
- Decatted downpipes
- TTE7XX turbos
- Uprated radiator (mishimoto)
- Uprated oil cooler (Litchfield)
- AMS coolant tank
- GT1R Air/Oil Separator
- Forge silicone piping
I've got some dress up bolts in neo-chrome that'll be replacing most of the one on show, but that'll be towards the end, priority is get it back on the road.
Plan is to get the car on the ramp and run engine in whilst monitoring for leaks, then dyno run in with logging/update maps.
Also after taking these pics I realised just how knackered my throttle bodies look! They'll be getting polished asap too.
The pipe clamp shown are only for use during shakedown. I'd ordered some snazzy looking ones then we realised they're too blooming small.. dope!
Tougher clamps on order.
More to follow...
