I'd assume so ?? ....my reasoning......
When the GTI-R boys go for larger injectors (550 and beyond) they tend to put in a different fuel pump too - of which the standard GTR pump often goes in.
Cheers,
Daz
Yes, you'll need to go to a pump with at least 250lph flow rate, I've gone for a Apexi 280lph pump. The Apexi pump is a straight swap IE no modifications required - just plugs into the existing connector and fuel pick up filter.
Jason.
