1 - 9 of 9 Posts
I've got a R32 GTR which will end up with 500-550hp this summer. When, if "ever", will I have to change the water pump to a better one? It appears as though the N1 pump isn't an option, so which one to get if any?
Discussion Starter #4
lightspeed said:
Why is the N1 not an option?
A search on the topic revealed that
"The N1 pump will work fine on an R33 block and an N1 block obviously. For R32's though there is a difference in one of the mounting holes which results in it not sealing properly and leaking."
Discussion Starter #7
Seems as though I'll be ok with the original pump for my application? Regular reving standard bottom end wit ~500hp or so.
Discussion Starter #9
So it's a recomended buy for someone who wants to drive the car on tracks a lot? I assume that'll qualify as running sustained high rpm? Order one, plug the hole somehow, install it and off we go?
1 - 9 of 9 Posts
