hi all
i need a confirmation from you that done it
i removed everything regarding hicas on my r32 and fitted the eliminator kit
what i want to confirm is:
when you remove the two lines going and leaving from the solenoid in engine room do you then loop those too? note i dont want to remove the vanes from the pump..i want to circulate my oil
thanks in advance
stav
thanks in advance
stav
