1 - 11 of 11 Posts
Anyone used one of these in the car?
Was thinking of buying one to run iPod for music and also charge my htc phone.
Don't want to use the cigarette plug as a charger.
My iPhone was always plugged in, but sometimes the music randomly stops... then I can't get it to play again :S no idea why this is, but it is really Fkin annoying! I've started taking my iPad for music because of it
Yep, I've noticed that too, seems to happen only when on long drives though.
Stupid phone.
Never copied the link.
Should be a link to a USB splitter.
Would a USB splitter allow charging of one phone and music from another?
Depends how the splitter is wired up. If one of the outputs has the data wire connected then you should still be able to play music with one of your devices whilst charging the other.
The USB splitters I've seen so far though are power only which would stop the music from streaming...unless you connect via Bluetooth which I find works really well.
I'm not sure what would happen if you got a small USB hub instead. I doubt the car could see more than one device and may even choose to not see anything plugged in to it.
Mine is inconsistent. Sometimes it happens within 10 minutes, other times it can go hours without a problem. Can't figure out if its the car or the iPhone
Discussion Starter · #9 ·
Yeah that's what my initial thoughts were. I can always try and make a connector up
Wmd, I used to get that problem with iPod touch. Then I did update via the 2012 or what ever year they were maps and the system has been great. Never cuts out now ;)
Is this a satnav update?
How do you know which version is installed and how do you go about installing the latest update?
Cheers,
M
1 - 11 of 11 Posts
