I am really tempted to go for a v-cam. My view on all the data looks to make an ideal street set-up for the low to mod range power. The question is if you are not chaising big numbers and you dial say mild cams in and keep the boost down , with enough ignition advance can you get the same effect from the very low off boost revs to the 4k mark ?
