1 - 20 of 25 Posts
Just need the pro version v-cam pref used
I do have stage 1 type b if anyone interested?
No longer need gearbox or plenum now
Thx
any pricing on stg 1? sorry for the late reply just posting a picture for reference.
"Can't you have kent regrind your current cam? Or a blank to suit"
V-cam pro uses a cam wheel with different swing range to the basic V-cam.
The cam wheel is actually just a modified Subaru one, so you could probably re-machine one to increase the range.
Discussion Starter · #13 ·
Interesting, as i had contacted RHDjapan and apparently they are discontinued :-(
the pro cam does have bigger lift as well
did you find it as a limitation with your build then?
Just wondering as im having mapping and work done asap with similar power levels. My kit is 9.7mm lift with 272deg cams and swing of 85-135 deg.
Haven't seen it advertised anywhere as any of the Vcam types i've seen!
1 - 20 of 25 Posts
