1 - 20 of 45 Posts
After an engine switch, I've been left with a load of engine & transmission parts that I need shot of. I did post some of these up previously, but I now have pics so this thread supercedes that one. Unless otherwise stated, parts came from an 1996 R33 with 50k miles.
Cylinder Head - £200
Intake Plenum - £75
Injectors - £100
Fuel rail - £25
Cam/rocker covers - £50
Centre cover - £40
Cams - £150
Crank angle sensor - £75
Cam pulleys - £40
Timing belt cover (top, with RB26 text) - £30
Twin turbo pipe - £100
Knock sensor - £40
Throttle bodies x3 – £90 (not inc, linkage etc.)
Throttle linkage - £40 (or £30 if bought with bodies)
Throttle position sensor - £20 (£10 if bought with bodies/linkage)
Throttle bodies to head sandwich plate - £75
AAC valve
Alternator - £100
PAS mount bracket - £30
A/C mount bracket - £30
Alternator mount bracket - £30
Turbo elbow pipes - £100
Fan belt pulley - £10
Gearbox cross member - £50
Engine mount (right side) - £50
Engine mount (left side) - £50
Viscous fan - £50
Prop shaft - £150
R33 Rear Diff - £400
2 x R34 Drive shafts - £100
R34 Front strut/hub assy - £100
R34 wiring loom - £100
R34 rear struts - £100
That's the larger items, but also got a load of other engine parts. Basically everything required to build an engine. The crank may be ok, but I'll post up as soon as I know, as I don't know for sure until I open the engine up (it has a rattly bearing, and I don't know 100% which one it is). Also have steel internal turbos, but I haven't checked them yet for shaft play etc.
Thanks for looking.
Dave
Discussion Starter · #19 ·
Hello I'm after the "Throttle linkage" please i'll need it freighted to New Zealand please please give me a E-mail on [email protected] kind regards Geoffrey
Hi Geoffrey,
Is it just the linkage you are after? Not the throttle bodies or position sensor? If so I'll weigh and work out a price for you.
Dave
1 - 20 of 45 Posts
