Vipec/Link G4+ plug-in ecu to suit R32/R33/R34 GTR and R32/R33 GTST
Upgrading my setup so my current ecu is up for sale.
Awesome ecu, Vipec v88 plug-in which if you know your stuff essentially is a Link g4+. (This is a late spec Vipec so is fully CAN compatible)
This is a direct plug and play ecu which is currently installed into an r32 gtr casing, but will also work with r32/r33/r34 gtr and also r32/r33 gtst.
Ecu is very capable and has a lot of features including anti lag/launch control, 4d dual tables, closed loop fuel control , open or closed loop boost control, real-time diagnostics and more.
Internal 4 bar map sensor and also Comes with additional upgraded link 7 bar map sensor.
If your currently running a stock ecu this is one of the best purchases you can make for the car, specifically on a gtr, it can totally transform how the rb26 behaves on the itb’s running Dual fuel maps utilising both tps and MAP for load inputs.
All in perfect working order and complete with original box.
Asking £850 + post (uk)
