1 - 6 of 6 Posts
My GTR has developed an odd vibration. It is coming from the front right corner and only seems to be when the car is turning slightly to the left.
I was driving home tonight doing about 70 on a motorway and the noise was a brrrrr for 2 seconds and then a seconds silence and then a brrrrr for 2 seconds. The vibration shortened the faster I went and extended the slower I went.
Any ideas?
Kp
Some GTR´s develop a driveshaft failure....maybe work to check if there is some play in the driveshaft...:wavey:
Would the play be along the length of the drive shaft or from the across the width of it ?
Kp
have you tried low speed full lock?
it could be driveshaft or brake disk/centre noise
What should I be looking for / listening for - there is the good old 4WD/AWD clonk that I have had on every 4WD car but anything in particular.
Kp
1 - 6 of 6 Posts
