Hi all,
Looking for a g'box solution for my track biased R32. Anything considered so long as it's still ok for normal road use.
Thanks,
Sam
Nice one Sam,get yourself a decent strong getrac,the ratio's are great be it 1st gears a bit short.
The one on eBay has been advertised for a while and slowly dropping in price,may be an idea to get a pre Christmas offer.:chuckle:
It's off a 33 so should have the required longer front prop and shorter rear section,and you will also need different clutch.
Catch you later Paul.
Thanks for the help guys - seems like the getrag is a good option.
Paul - thanks a lot for that.. Do you run a getrag in your car? If not what do you use? My car already has an r34 motor so would I still need a 34 clutch? Guessing so but a bit of a bummer as I just got my os giken rebuilt.. No idea what the prop shaft would cost but hoping it wouldn't be too steep. As you can probably tell I have no idea about these things! :( Good luck for brands too mate, hope you get some good weather and put some times in to scare the R35's :) :)
Cheers!
