Hi,
When the weather is really hot (air temp of 30°C or more), I've noticed that my water temp tends to go above 90°C when sitting in trafic, at idle.
When cruising or pushing the car quite hard, I have no problem at all: water temps goes from 80 to 90°C, no more.
But when I'm caught in congestions, the temp slowly goes up...
Am I the only one to see that? (my water temp figure is rather accurate as I read it on a defi gauge, not on the std instrument)
BTW, I have N1 water pump and Koyo alloy rad, idle is set @ 900-950rpm with aircon switched on.
Oh, and the electric fan in front of the rad is working.
Should I go for a bigger electric fan? Or could it be my viscous fan?
