I seem to have this problem with my r33 gtr, anybody know the cause of it?
P Paul-r33 · Registered Joined May 1, 2011 · 32 Posts Discussion Starter • #1 • May 16, 2014 I seem to have this problem with my r33 gtr, anybody know the cause of it?
JTJUDGE · Registered Joined Nov 21, 2011 · 4,573 Posts #2 • May 16, 2014 even I know this one, it's the hole at the bottom of the water pump!
P Paul-r33 · Registered Joined May 1, 2011 · 32 Posts Discussion Starter • #3 • May 16, 2014 Deary me how did I miss that? What causes it to start leaking water from there?
Asim R32GTR · Registered Joined Sep 24, 2003 · 1,883 Posts #4 • May 16, 2014 The seal on the propellershaft is leaking. So they made this "inspection hole" to let the owner know when the seal has gone bad. You need to change the waterpump.
JTJUDGE · Registered Joined Nov 21, 2011 · 4,573 Posts #5 • May 16, 2014 Is there an actual hole or is it just leaking through a joint/seal
cox · Registered Joined Jan 21, 2012 · 964 Posts #6 • May 16, 2014 happened to me.... only a new water pump can solve the problem....
P Paul-r33 · Registered Joined May 1, 2011 · 32 Posts Discussion Starter • #7 • May 16, 2014 Cheers for that, I'm on my way to get a new water pump, at least it's not over pressure that's caused it
