Just a quick little project on my GTST, its easy and simply, however, the ONLY problem i have now is that since the Inter cooler of my R33GTST is sooooo low , well below the reservior's level, water drips out thru the jet due to the "siphon" effect. Is there anything like an "anti-siphon" valve i can have along the lines??? where can i get such thing..?? Or a jet where it only crack opens under a pressure (very low pressure of course since the little pump i use is just the washer pump..)??
Any ideas appreciated.
Halfords do little NRV,s which is what i fitted into my system.
Mind you it took 3 off them :eek:
The NRV,s put a little bit of resistance to the flow and the 3 of them provided enough to conteract the head of pressure from the water tank.
Hope this helps
Best regards Alan :D
