Any of you guys had this before..
R32 GTR, Headlamp bulb on the passenger side of the car goes out. Think o.k I need to replace the bulb, driving home last night the bulb starts working again... Think, must be a dodgey bulb then, turn the lights off and on again and it stops working..
Move the bulb to the drivers side to test it and it works every time, move the known good buld to the passenger side and it does not work. Weird huh..! Well got the ameter out to test the voltage and when I get a reading from the passenger side contacts I read 11.9 Volts, same as the drivers side. You put any bulb in and the voltage drops to 0.
Looked for fuses and can not find any for the dipped beam only full beam. Could this be the switch on the dash??
Any ideas most grateful as I have been pulling my hair out about this.
Malc
Malc
