1 - 6 of 6 Posts
when the car is warm and i reverse up a slight incline I get a loud slipping low humming type of noise which is matched to the revs, is this normal? I have only had the car a few months and it doesn't always do it. Only when its warm!
If no one can help with my rubbish explanation I will have to try and get a video:confused:
I have long given up worrying about all the weird noises gtrs make. Its no good for ones nerves
If it breaks there are enough specialists around to make repair costs liveable
Did you ever get to the bottom of this as mine also does it in 1st & reverse in a slight incline and between 1st & 2nd at low speed when cold. Sounds like something is be starved or struggling of flow.
Anybody know how easy it is to check the gearbox oil level? Can it be done without a ramp?
I never did, and mine does it mainly when its hot or been given a hard time. I decided it was just another noise that the GTR makes!
Mine has only really started to do after I fitted a 14 plate clutch, I'm going to keep running it for the mo and look into when I plan the 1st gear upgrade or the complete gear set change out.
1 - 6 of 6 Posts
