someone mentioned that if you use the apexi boost controller with the apexi pfc, unlike any other make of boost controller, it is able to work with one another and so adjust the map/ecu settings as like a OEM ecu, like, if there was a boost spike etc etc.
(lm not too clued up on the mapping side, just regurgerating what another member has said)
I'd also like confirmed if the apexi pfc is able to do this, as l might ditch my special edition BEE-R blitz controler/I.D
Where do l have to mount it?you would still have to mount the sensor, as in any setup of boost controllers
If you already have d-jetro fitted with the 2 MAP sensors then you don't need to fit another one for the boost control kit. You'll just have to fit the solenoid.Where do l have to mount it?
Will it be a pain in the arse as the two d-jetro sensors were.
