I have these fitted but want to know what Diameter the intake pipes are?
I should know but cant find any info on Litchfield's site?
Louie
Louie
Thanks budEither 76 or 80mm I'd guess.
I think Litchfield use the intake pipes developed by Forge, you will know if they look like yours.Thanks bud
That's my conundrum.....I'm currently at stage 3 (via Sly) with Downpipes & EcuTek V4
However I'm considering going to 4.25 via SVM (650R) Im not looking to go further as its then Turbo's and I'm not looking to spend to that level.
Seeing as I have the majority of upgrades I've been advised by Amar to
- Fit 1050 or 1100cc injectors
- Fit 102mm Zorst Non Res & Y
- Remove Litchfield foam Cone filters and replace with K&N cone filters
- Upgrade the existing OE intercooler pipes to Samco's (Apparently these are larger than the OE pipes?)
- Re Map to cater for new larger injectors
Amar reckoned that the existing Litchfield MAF intake pipes are poss 74mm I.D whereby there's are 80mm.....So I'm trying to get confirmation on the pipe I.D for my own peace of mind
Also Will upgrading the Intercooler pipes to Samco's take any of the restrictions out of the OEM pipework?
Louie
