1 - 9 of 9 Posts
It came out of an R33 GTST and has an ABS sensor and when i spin the tailshaft end both spin in the same direction. Here are some pics, also not seeing a viscous sticker anywhere. I gather it is a 4.11 diff and think it is LSD as well and has ABS which is good as it is going in an S15 RB26DETT powered.
Thought LSD diffs rotated opposite directions when rotated?
bob
Actually, actually no i think its the opposite to that, if they go in the same direction its an LSD!
My bad.
bob
Its not 4.11, its 4.36... markings show 48:11 = 48/11 = 4.36
That will be a very nice ratio for a 26 :)
EDIT: it's a diff from an R33 GTSt auto in your case
Oh yes I only remembered when you did the calculation, 48/11=4.36. Should be sweet then good for light to light fun ;).
Discussion Starter · #8 ·
Can anyone tell if it is a VLSD or regular LSD? I am wanting to refill it same time as it is out before putting it up in there. What fluid should I use Redline Heavy 75W90?
Discussion Starter · #9 ·
I want to confirm that it is a VLSD, can someone confirm that and also what fluid I should be using, whether to use the Heavy Redline Gear Oil or what are people using?
1 - 9 of 9 Posts
