I am getting ready to install a new boost controller in my car. I had a look last night at the existing one and also the standard solenoid pipework.
My guestion is on the existing one, there was a fuel pressure reference pipe, a boost pressure pipe that tapped into the actuator reference pipes and then another that went round to the inlet plenum side of the engine and appeared to go into the engine under the plenum.
Looking at the standard solenoid, this pipework simply seemed to have two hoses, one out the front and one out the side that also went under the inlet manifold.
what are these doing? I assume measuring the MAP pressure?
puzzled and not sure what to do with these tubes when I fit the new greddy profec controller?
any advice would be really appreciated
thanks
Martin
thanks
Martin
