1 - 12 of 12 Posts
Noisyone said:
not sure matey but i did have a set of KAI coilovers on my skyline when it came from Japan i think it was KAI office
That's Kei Office, as in Keiichi Tsuchiya.
This is the best I've found about "Kai":
"KAI or Kai (for Kaizo) is a Japanese-language technical designation suffix for referring to factory or operative front base modifications to military aircraft.
This term is equivalent to the German suffixes U (Umrüst-Bausätze = Factory Modifications) and R (Rüstsatze = Operative combat land Modifications) used by the Luftwaffe. These alterations are made in factories or air bases in combat areas."
So it means it's a modified version of a T51. Perhaps.
Phil
Banned
Discussion Starter #4
Phil
Either that or the turbos were designed for a fighter jet.;) Thanks.:)
I actually saw some N1-Kai turbos. That's where the question came from.
Then, what does SPL means? I mean, i've seen HKS use it on T51R...
This got me wondering what does it means? can someone enlighten it up?
Grant
from my knowledge, i think KAI means racing. There are two version of HKS T51R, the T51R-KAI mean 'racing' and T51R-SPL mean 'special'. The SPL version came out later with more power but more lag due to different turbine. T51R-KAI rated at 800-900bhp,
T51R-SPL rated at 900-1000bhp
JasonGTR said:
KAI means modified.
Like over here in Japan if you swap an RB26DETT into your GTS-T, then you must get your title changed to a KAI title. I just means Modified.
That's it exactly.
The SPL uses a larger turbine and compressor wheel. Garrett built the unit for HKS. Its based on the same basic chassis as the GT42.
Banned
Discussion Starter #11
Which is better in terms of power, boost threshold and spool?
In terms of power the SPL version will make quite a bit more, but the trade off is lag. For a street driven setup the KAI would be the best way to go, but if you call forcedinductions.com they can get you the Garrett version which is the same, and is a good bit cheaper. That is what we do.
1 - 12 of 12 Posts
