1 - 20 of 20 Posts
Currently running litchfield stage 1.. few weeks im going litchfield stage 4.25 etc..
Im debating what exhaust to use etc as i have a good friend that is currently fabricating his own systems..
So i dont know what spec to go for?? Do i do a full 4" system?? And twin back boxes etc...
Or a 90mm system?? Want it to be right and want a good sound but dont want it to drone..
Can anyone advise what spec i need to build regards diameter etc and downpipe sizes...
Once perfected they can be produced to order as my car will be used as a demo etc
Could even consider a valved system perhaps
Any advice appreciated :)
Just buy a Russ Fellows system, very little point in your mate producing another exhaust system as the market is already saturated with different suppliers.
Discussion Starter #4
Cant really refuse when its offered me at cost.. why pay russ fellows £1500+ when it might only cost £1000 for same system maybe less :)
Sorry I can't advise, but have often wondered if a 102mm system is a bit overkill for stage 1 -4, normal remaps.
My own experience is that I need stock downpipes, probably too loud with decat downpipes.
I like the secondary cat removed and replaced with a non-res Y pipe.
I like 2 small silencers in the rear section, as again a straight through rear section is too loud and barky for me.
I like titanium for the screamy higher pitch sound on power.
I'm not bothered with valves, if I want quiet I choose low rpm and keep foot off the gas.
I like to see competition, if your mate can build quality titanium systems at 500 a pop less than GTC Titan systems, I think he'd gain some customers.
Discussion Starter #8
Well its a learnin curve so just lookin for ideas and to help him promote into the gtr scene etc..
Just want the right sound out of mine without the overkill etc
you get wot you pay for !!! bye cheap buy twice :)
Had that discussion on previous threads - I have had it on for 2 years 7k miles its not rotted away still shiny mine fits perfectly others had issues with the tips being lower on one side- all I can say is for the money they are a bargain and imo sound good
True in my case. I started off with a stainless 3" resonated Y pipe, then 3" catback, and finally downpipes. The sound improved with each step but so did the drone which was too much once the DPs were added. I switched to a 4" titanium system (GTC Titan) with a non-resonated Y pipe which sounds awesome and without drone. So I'd recommend going for a 4" set up to remedy the drone issue. Titanium over stainless is another argument; both sound great with my slight preference going to titanium. All relative though :cool:
1 - 20 of 20 Posts
