1 - 13 of 13 Posts
I bought an engine and opened the sump and found a lot of gasket stuff and something rubber-like in the oil-pick up and in the sump.
Is it possible the heat makes the gasket material black and hard like rubber?
I also found this piece of aluminum along with some metal filings but I want to know where that piece belongs. It looks machined on one side and casted on the side where it broke off.
Sorry for the lousy pictures.
Yes, heat and time does tend to make gaskets brittle, depending on the gasket material that used. Are you doing a rebuild?
Is newly built? Looking at that oil, its not too new.
Did you do a leak down, or comp test on it?
No never got that far. I got suspicios when i looked in the rocker covers and saw the oil, pulled the sump of and found this stuff. Main bearings needs replacing too.
Fully forged engine. Just been run in...
Looks like bearing material in the pickup and it looks far from a new or clean engine to me.
Do you really know the history of the motor or is it one you just purchased?
Rob
Discussion Starter · #9 ·
Rob
I just purchased it. I´m pretty shure there is no metal in the pickup. It is rubbery bits with oil on them that makes them look shiny.
Top pic looks like brass/copper colour metal parts from bearings.
If that is a newly built engine I'd be very worried man,
Rob
Discussion Starter · #11 ·
I got worried too, thats why i made this thread. I pulled the crank out and it doesnt have a scratch in it. The seller is going to send me new bearings. These pictures is the 3 worst.
I cleaned the engine from the sump and from what i can see from there it looks fine.
Maybe its just had new bearings fitted (hence the newly rebuilt) but it wasn't cleaned out properly from the previous failer?
The bearings on those first 2 pix show crap has gone through them also, where's it come from?
Rob
Discussion Starter · #13 ·
Everything is new, crank, pistons, rods cams etc. He thinks the head wasnt cleaned out properly from the company who did the porting job.
1 - 13 of 13 Posts
