Hi guys my car had developed smoking issue and from the symptoms i thought my turbo seal were shot so i brought some 2860-5 my old turbos were removed yesterday to find oil in both turbos i was kind of expecting it anyway, but when removing the manifolds oil was found ONLY in and around cylinder 1?? what does this mean??
could it be-
Oil from the turbo seal?
Valve stem seals
Head gasket
Piston ring (s)
Would like to know what everyone options, in the mean while. im having a compression test done tomorrow so I will know if its the pistons or not but would like to know from others who have had the same issue?
o dear! You remember when you took me out in it and i said its alot slower than mine? Well thats proberly why! Your only running on 5 pistons!
the exhaust valve is where the oil is coming from i guess. I would also guess that there is something wrong with that valve stopping it shut giving the low compression reading.
Get the head of and have a look. If your lucky its just the head that needs rebuilding.
If it was a piston problem i would guess the oil would of been burnt off when last run. That oil must be coming past the valve stem seal when the car is not running.
This car has never snapped a cam belt before or something has it?
I have never been in another R34 GTR to compare the differences so I guess it was slower then yours then it must have been running on 5 then.
Heads coming off Monday im hoping its a valve and/or valve stem seals and not pistons as you said matt it would have been burnt off when last running and loosing the oil on cylinder 1 when the car is not running? Fingers crossed.
As my engines coming apart tomorrow its could be one of many things that has caused the problem like
Valve stem seals
Head gasket
Piston ring (s)
piston
where is the best place to source these item at a reasonable price wanted to change my cam belt while its apart with a half decent cam belt any suggestions of brand? and also where to source it from?
is there anything i have missed or should change while its apart?
if your getting alot of oil in the front of the turbo's and in the intake pipes you could be getting pull over but the low comp on no. 1 it could be a few things. i had low comp no no. 6 on mine and the piston ring glands broke taking the cylinder bore with it. i hope you have better luck with yours though.
Well head came off today and the valves and valve seals are all ok but when inspecting cylinder ones bore its seams to be damaged (scored) and it wont hold any diesel fuel which suggests piston rings? Well engines out tomorrow and block will be removed from the engine for reboring at an engine centre, can someone give me details about the reboring process from my understanding the bore gets machined (oversized) a little and you need a bigger (oversized) piston to fit it? Do all bores need to be rebored or just the one? (damaged) I will be changing all piston rings but do I need to change all pistons for oversized pistons? I will also have the head skimmed and pressure tested. Is there anything else I have missed that needs to be addressed?
Bash, how do you know the valve seals are o.k? Im looking at them pics and number 4 as i think chris said has had some major oil flowing in plus some of the others dont look the best.
If all the other cylinders are sound then the oil must be coming from above. Also after speaking to you on the phone the other day and your engine builder was not going to be recutting the valves etc while the head was off i was getting a little worried for you. Also there was no leak test done on these valves while the head was off. Your engine builder should be giving you the options etc of what can and what will be done rather you ringing me and me saying is he doing :blahblah: and so on for you answering no etc. (im not saying dont phone me mate LOL... )
To be honest mate i think i would be deciding very carefully who should be building your engine. Yes you may save 1000 quid with your present builder but these engines really need someone who knows there stuff working on them. If you get something wrong you will be paying for it to be done a second time plus more new parts.
Have a good think about it mate. The engine builder i put you into has plenty of space around his unit so i would guess he would build at your speed to match what ever money you have avalible.
P.s MGT Racing use a plate for honing and building also! Also the price MGT quoted you, did that include honing/skimming/cutting valves etc? I guess it would have. If so i think you need to add up how much your engine builder wants ontop of all these extras. After thinking about the price MGT gave you to rebuild your engine i think you cant go wrong really as you know they have the kit and the knowledge to build your motor.
Plus after my last few visits to them, well im more than happy with what i have seen and purchased of them.
yes they will bolt a torque plate to your shortblock and hone ALL the cylinders, the more stock the bore usually the better(most people feel/think that stock bore builds last longer than stoker builds)
then you will just drop in a barely larger than oem forged piston that will come with a set of rings. If you are running high boost you want a looser ring gap, ask your engine builder...and make sure they specialize in the rb motors
hopefully you can just refinish the heads surface and buy a gakset set and just re attach the head without any work to the heads...you should have done a leakdown test as well, pity.
Thanks for or reply MorePSiTehbett4. Do you know by how much they hone the bore? The original bore on a RB26's are 86mm is this correct and the same for all R32-R34 models? So I am guessing they are honed to 86.5 mm or 87mm depending on how bad the bore is? I was considering Wossner pistons what is your opinion about these, will they be ok to fit to a standard block? Is 1.5 bar of boost a lot? Will I need looser ring gaps? The mechanic that is building my engine does not specialise is RB's but is well clued up on how to remove and put this engine back together. I will be using a engine specialist to hone my block and will probably have the head pressure tested and skimmed just to be on the safe as no leak down test was done.
Good grief
Ive never seen an engine have a torque plate put on it to hone bores.
Whats stock bores builds got to do with strokers ?
Stroked engines have a different stroke not necessarily a bigger bore.
NO
They will be bored to .005 under .5mm oversize and then honed to the finished bore size.
If the bores not rooted and its not a particularly worked engine see if you can buy 1 standard oem piston (assuming thats what it has)/ hone the bores and just re ring it and stick her back together.
Good grief
WTF
The only option is increments of .5mm
NO
you've never heard of someone being honed using a torque plate??? Yes, he might get away with just a light hone if he still has the crosshatch. I would recommend doing it right the first time and just doing them all and have a fresh sb.
usually people increase the piston size as well as the stroke; as in most stroker kits.
Thanks for the reply glen when I contacted the engine centres they wasn’t to sure why/ what a torque plate was/needed for when boring.
So I will need to ask the engine centre to increments the bore by 5mm only and fit the original piston with replaced rings?(correct me if im wrong as im not clued up with all this piston stuff still learning) from my understanding just the damaged bore will be bored (cylinder1) and the rest of the 5 cylinders will be honed. My car has original internals including pistons but when you say replace with an OEM piston isn't there going to be a gap between the bore and piston as the OEM piston will be 86mm and the bore will be alt bigger? Do you mean replace with an OEM piston which is over sized? Please point me in the right direction.
If one bore needs boring over size you must bore them all and fit 6 new over sized pistons. If you are incredibly lucky you may find any bore damage is restricted to number one, and it's so slight that a hone will clean it up. I would suggest all cylinders are lightly honed though to de glaze them. Be sure you replace pistons like with like, make and compression height wise, if you just renew one piston, and weigh it against the other 5. I'd be more concerned about WHY it has happened, det would be my odds on favourite.
When removing the cam belt cover the timing belt was pretty loose, after inspecting the timing it was one tooth out so I guess that is why this has happened I am putting it down to timing belt stretched or tensioner giving way? Any other thoughts how this could of happened?
Could have bent the valves.
TBH if the #1 bore is so damaged that it "Needs" boring, then as you have fitted 2860r-5's I would suggest fitting a set of .5mm oversize forged pistons.
Again, get the engine reconditioner to inspect the bore and advise.
IF the bore is fine, just have it rehoned and fit 1 standard pistong and a set of rings but like chris says, if 1 bore is toast, you need to rebore all the cylinders and fit oversize pistons.
It may well already have oversize ones, who knows ...
Again the reconditioner will boremike them and advise.
As a general rule
Assuming the bore need minimum to to clean up
1st over size 86.5mm
2nd 87.00
3rd 87.5 and you can bore them to 88.00
BUT the general consensus on overboring is large power engine dont like anyhting over 87.00 as you quadruple the chanced of splitting a bore.
99.9% of mildly tuned are 86.5mm
Thanks for the reply glen and chris. Once my engines is out will have the engine centre look over it and pressure test the head also to check for valve damage. If the damage is bad will have all bores bored out to 86.5 mm assuming it hasn't been bored out before and fit a full set of over sized pistons.
rebuild part list
Valve stem seals
Head gasket kit including inlet side (any Idea what size metal head gasket to fit?)
over sized pistons with rings (86.5mm)
cam belt (can someone give me some recommendations on brand)
belt tensioner
I was considering fitting a oil restrictor and head oil drain to sump for future oiling issues, wanted to know what fittings I will need for the head oil return to sump as i have a standard sump will i have to modify that sump or is there somewhere I can attach the return to?
Do you think I will need the head oil drain to sump? Going to run about 600 bhp. With some track days, don't want to suffer a spun bearing
What head gasket size should I fit?? what does the gasket depth depend on?
