SIMPLE.... What oil comes in a GT-R as standard..... Just so I can top it up.... Thanks
A Amos · Registered Joined Nov 14, 2005 · 97 Posts Discussion Starter • #1 • Oct 8, 2009 SIMPLE.... What oil comes in a GT-R as standard..... Just so I can top it up.... Thanks
O oilman · Registered Joined Jul 16, 2004 · 1,849 Posts #3 • Oct 9, 2009 Yep, Mobil 1 0w-40 Mobil 1 0W-40 Advanced performance synthetic engine oil Cheers Guy
D David.Yu · Premium Member Joined Jun 28, 2001 · 5,031 Posts #4 • Oct 9, 2009 But it's not the oil you'd recommend for any seriously driven GT-R, eh Guy?
O oilman · Registered Joined Jul 16, 2004 · 1,849 Posts #5 • Oct 9, 2009 There is always better if you want it! Cheers Guy
Hazardous · Registered Joined Nov 30, 2007 · 218 Posts #6 • Oct 9, 2009 So what would you recommend for a seriously driven GT-R? or for a GT-R that you want to look after well?
O oilman · Registered Joined Jul 16, 2004 · 1,849 Posts #7 • Oct 9, 2009 Mobil 1 is very good, so no issue with it. If you want better then ester based synthetics, Silkolene Pro S, Motul 300v, Redline, Gulf Comp. Cheers Guy
F Frenchie · Registered Joined Aug 18, 2008 · 117 Posts #8 • Oct 13, 2009 But what about the transmission oil... does someone know the brand? I'd be interested to get some without the "GTR tax".
O oilman · Registered Joined Jul 16, 2004 · 1,849 Posts #9 • Oct 13, 2009 We recommend the Fuchs ATF5000 tried and tested by GTC Fuchs TITAN ATF 5000 SL Fully Synthetic, Heavy Duty ATF However it will not be covered under warranty. Cheers Guy.
