im wondering what is the optimum pressure to run a gt3071r on an rb25det with forged internals slightly lower cr and tomei poncams? im purchasing an actuator for the turbo and wondering weather to get a 1.2 bar or 1.5 actuator:wavey:
I have 2 :) Depends what you want to do with the car. If you want a low power option, then up the boost with a boost controller then go with the 1.2bar
If you want to max it out, go with the 1.5 as you'll need the stiffer spring to hold max boost
