Based on the Nismo version road car which was the RS500 style production run of evolution BNR32.
Approx 600hp maximum.
Nismo RS580 turbos.
Nismo 550cc injectors.
Reinik cams, cam wheels, oil pump, forged cooling channel type pistons, fuel rail, alternator bracket, sump baffle, oil breather. Modified stock rods and crank, Group A block. Nismo version exhaust manifolds, stock intercooler, big radiator and massive oil cooler. Extended sump made from 2 stock sumps. . AP or Tilton small diameter multi plate clutch.
In addition.....
Uprated drive shafts and CV joints front and rear, carbon propshaft, magnesium uprights and custom suspension linkages, 10x18 centrelock wheels, close ratio dog leg or sequential box, AP/Alcon brakes - (even carbon discs), magnesium casing on the transfer box, modified subframes with revised pickup locations, diff and box oil coolers, Stack 'GT-R' rev counter....
Weight around 1070kgs.
