1 - 14 of 14 Posts
Tein type ha, would be ideal for track use. Will be removing a set from my car this weekend to be replaced with super streets.
Do Moton do stuff for Skylines? If so they're the absoloute nuts but you'll pay top dollar for them.
We found AST triples work real well , but we didnt use anywhere near to the spring rate lightspeed quoted , think we ended up with 9kg front and 7kg rears. Run with stock front bar and big rear bar set pretty stiff.
If you can afford the stuff front and rear ikeya links and stretch the track at the front by at least 35mm if possible.You dont need to stretch the rear thou.
Front LSD diff will work well , but run without a front bar connected.
dont run the car to low as it will cause excessive wear on the front top links.
Is that reel slicks recommendation or for use with semislicks?
Do you have a slicks recommendation? I´m going for Dunlop slicks (245/40-17 from STCC series) this summer, not racing but just for fun.
I have a pair of quantums fronts only, back ones need to be fixed. im selling if interested.
Graham
Discussion Starter #12
Thanks, I will be running Michelin Slics, Whiteline svaybars, hopefully full Ikeya front setup (Maybe only shortened upper arms..) and stiffer shocks/springs. Superstreet now on max...
1 - 14 of 14 Posts
