1 - 20 of 235 Posts
So having made 1101 whp but followed by an engine failure due to bad machining by CNC Heads (Ric Wood) I was forced to start again, So heres whats planned for 2020
Engine
4.1 stroker
Callies custom crank with Big Block Chevy (BBC) size big end journals
New stock block
Custom Carillo con rods with BBC pins and bearings
Custom Mahle Pistons with BBC tool steel wrist pins
ATI Super Damper
CNC ported cylinder heads
GSC Billet cams with springs
Nitrous Express GTR kit
6 X 1050 ASNU injectors
6 X 2000 ID injectors
Billet throttle bodies
Linney Billet flywheel
All ARP bolts, studs and hardware
257727
257728
257729
257730
257731
257735
Discussion Starter #2 (Edited)
Turbo Kit
Option 1
Stock manifold GT3584RS
Endlesteing heat coated
3" suction pipes
BL Ti intakes with K&N filters
T1R AOS
Tial bovs
84mm downpipes
(kit is brand new for sale complete ready to bolt on, will do 1500whp on race fuel)
Option 2
Custom one off turbo kit with external gates, spec classified !!!!
Drivetrain
Dodson extreme trans with O/D 6th
All billet shift forks
Billet midplate
Billet awd plate
Linney rear Diff
Linney trans brace
Linney billet diff cover
Linney drop gears
DSS heavy duty rear shafts
Maybe Albins longer rear crown wheel
Linney billet 10 plate ETS
Linney uprated AWD shaft
Extreme 20 plate clutch
ACS/GTRP uprated FWD prop
Linney billet front diff
Quaife front ATB diff
Maybe Albins longer front crown wheel
PPL billet bearing holder
Fuel
3 X walboro 480 pumps staged and hard wired
Radeon 3 - 1 -10 adapter
Radeon -10 filter with heat sink holder
Custom fuel tank fuel hanger
Custom fuel cooler
BL fuel rails with 1050 ASNU injectors as primaries
Flex fuel
Weldon pressure reg
-10 BMRS supply line
-8 BMRS return
ASNU 3rd rail with 2000cc ID injectors
ASNU 3rd rail injector driver
N/Ex 300hp nitrous kit
Maximiser 5 controller
Cooling
PWR alloy radiator
GTRP 5.5" FMIC
CO2 Intercooler spray
Think automotive custom oil cooler 30% more efficient with cooling fan
GTRP trans cooler kit
Think auto PAS cooling rad
New AC condenser
Custom fuel cooler
Wheels
Set 1 road, DBA with Runflat tyres
Set 2 track, BBS with Nismo runflats
Set 3 strip, AMS 17" rear with various drag tyres , Enkei PF01 with 18" M&H racemasters.
Set 4 Belak beadlock drag wheels budget permitting
Body
Mainly stock
Litchfield bumper vent
Carbon splitter
Canards
Import racing wing vents
4SRC ducktail Carbon boot for street Custom pro mod style boot for drag and Vmax
Twin parachutes
Battery jump posts in rear plate recess
USA bonnet hinges
Suspension/brakes
Stock CBA shocks with DSC suspension controller custom maps for street , drag and track by Hugh Kier
DBA 380mm front discs Linney pads
Stock rear discs ferodo 1.1 pads
RBF660 fluid
Imprt racing brake stopper
Interior
Unsure final spec
Corbeau bucket seats
Import racing seat mounts
Luke Harness'
Heigo rear roll cage and harness bar
No doubt ive missed a few bits that will appear as the thread progresses , pics following of what we have already, other parts like trans are in Cheq Republic, heads Austria and mid way from the USA
  • Like
Reactions: Hugh Keir
Discussion Starter #4
  • Like
257755
257756
257757
257758
257759
257760
257761
257762
257763
  • Like
Dude i used to live up the road from your garage in the Supra days. Used to be stunned at your car then. Looking into a GTR now and i see you have taken it to the next level with the GTR too. This will be insane. Will follow with interest.
CNC heads builds svms engines don't they ?
Bad luck with your motor what caused the failure ?
R35 Section manager
Interested to know how the first motor failed?
The new project sounds even better though.
Administrator
great to see this, I assume you found it nice and easy to add all those pics (and imagine you wouldn't have bothered on the old site?)
Fantastic spec and will be great to see pics of the build. I am limiting my 64 Reg GT-R to an 800ps limit and it's currently around 700.
Discussion Starter #13
The motor failed simply because CNC heads did not do the line bore correctly, the 2 middle main saddles were out of line, the motor failed after I lo9st a plug tip at bruntingthorpe and scored the bore, because it was almost impossible to find the cause it was put down to the scored bore and material in the oil, I had no argument to counter this so just had the second engine built, I was on a time line as were going on the B35 tour to Norway, CNC heads did not do anything to my engine as they were filming car SOS !!!! So 3 months in with weeks to go I started kicking off, the engine builder got on CNC heads back and soon had a call saying block done new liners etc, I can tell from what was said that they had purchased and fitted and machined the liners and not even checked the bottom end to see if it was even serviceable! So builder told oh we need another few days, they pick the motor up and start building, about midnite I get a call saying they cant get the clearances they want and motor going back to CNC heads and they will wait for it. Apparently they hand polished the crank to get clearances !!!!! Back to the shop and the guy laying it all out on the bench noticed something interesting, the witness marks from girdle and block from first failure were still there! So how did they re alignbore it? Anyway crank was put in clearances achieved and I picked motor up, put it in car ran it on the sat before leaving fri for Norway, we had a few teething problems and could not drive the car till weds, Dimitri put a map on it weds evening, very toned down to get some miles on the car and he would remote map as it was going across Europe.
He said do a decent pull to check the fueling and the oil pressure dicked around, I spoke to builder and we both concluded the sender was iffy, went to 4 bar and stopped dead, did 3400 miles inc that in GB in 8 days, put car on dyno and it was 675whp, we turned it up and got 1101whp @ 2.1 bar must have had over 20 pulls as a VVTI solenoid was faulty and Dimitri was asking for far more % than usual to achieve what he wanted, got back to shop and Imran next door had a solenoid so we fitted that and road mapped it to 2.6 bar the night before TOTB
First run at 1.6 bar it tripped as it went into 3 due to seeing to low a pressure vs RPM, when stripped the 2 middle main bearings were identical.
I claimed on the builders Liability insurance as their Insurance company would claim against CNC heads insurance, they had a forensic engineer (******) who looked at it but knew what to look for as I had sent videos of it being measured and a clock run over the surfaces, it then went to be measured on a machine that could be used as evidence in a court case and the problem was found to be faulty align bore and not a result of negligence of the builder (remember they cant check the align bore, the people the asked to check it are the people who did it)
I firmly believe that CNC heads never did the second align bore at all and just sent the motor back.
Oh and to add insult to injury all the liners the idiots fitted had pulled into the block so it would have hydraulic-ed anyway eventually.
So CNC heads bunch of clowns Ric Wood absolute pRic and I hope the insurance company sueing you get every penny because you dont even do the align bore you sub it out and double the price to the customer so good luck coming up with a invoice so your company can sue the people you use (name witheld) who I know exactly who they are.
So thanks to CNC heads I have been without my car for almost a total of 2 years.
Amazing spec John, can't wait to see it run. Feel free to message if you want to talk through fuel options.
A sad story on the engine build. This stuff isn't cheap and it always amazes me that work can be done without the apparent appropriate care being taken. 2 years is terrible, at least you're nearly back and good luck achieving your goal.
Discussion Starter #15
Well Mook once I got my head round it yes it was quite easy but I would have done it on the old forum maybe a bit easier but this way was cool once I figured it out.
  • Like
Reactions: Mookistar
Discussion Starter #16
Wow mate hope your seats are going to be easy to clean once this is all up and running!
Wipe clean been specified (passenger side) I think she will be very docile on the road being 4.1 and slightly higher compression however on race fuel and N2O she should be a beast.
Discussion Starter #17
Looking forward to us all being out again next year Martin, Ive spoke at length with Jeff re the fuel.
Discussion Starter #18
Come say hello at Pod, Ill give you a passenger ride but I wont be allowed to do a full pass with you in, we can let off at 1000ft and keep them happy, they wont allow over 150mph with passenger on board.
  • Like
Reactions: AdrianB
This is shaping up to be a great thread, can't wait to see how things develop dudersvr. I'm still a novice and learning about the GT-R after a year of ownership, so its great to see those who know about building quick cars share their time and knowledge going through parts choices/options, engine builds and upgrades. Hopefully you'll have time to update on how the build is going and pictures of the beast when its taking shape and then driven - that's quite some spec list!
Discussion Starter #20
Yes as soon as we get going next week, will do regular updates with pics, we aim to be out around Easter testing.
1 - 20 of 235 Posts
