At the moment im running a stage 1 R33 GTR with the usual--standard turbos, injectors etc. I have a few parts to go on including R34 N1 turbos, HKS 600cc injectors,HKS turbo elbows, Tomei fuel pump, Nismo afm`s , hard pipe kit and oil cooler/relocation kit.Im looking at running about 1.2bar as im on a standard head gasket but might be persuaded to change that if i really need to.I have the usual exhaust, front pipes, decat, Power FC , plugs etc....
So what bhp/torque should i be looking at for 1.2 bar and again at 1.4 bar ( flywheel figure would be ok...
Remember im running standard cams and im not changing these...
Snap!
Your spec is almost identical to what I'm getting fitted at the moment, also sticking with standard cams. I should have dyno graphs to show the outputs at various boost in 2-3 weeks time.
We did a baseline run on the dyno on Saturday for comparison purposes, which you can view here:
http://www.gtr.co.uk/forum/upload/68713-baseline-dyno-graph-stage-1-r33-gtr.html
As you can see, my stage 1 tune is not a bad starting point ;) I hope this carries through with the new mods :)
