Had Power FC mapped up to 0.9 bar, couldnt go any further because the boost controller was'nt working properly.
Fixed that now, and on the way home i gave the car a little squirt @ 1.2 bar (GT-SS turbo's) but the warning light flickered for a second at about 7000 rpm.
On the hand commander, the stuff being monitored is, Injector duty, Air Flow, Timing, and Knock.
I glanced at the commander, but obviously because i'd eased off, i didnt know which one of these readings caused the flicker, but i presume it was the knock sensors.
Ive turned the boost down to 1.0 bar and have been monitoring the knock level meter all day, and it doesnt seem to climb much higher than a quarter of the way up the scale.
Does anyone know the 'safe' zone for the meter reading?
i.e., how high can it go before it all gets a bit dodgy?
And can you get a peak reading from the hand commander after you've finished your journey? If so, how?
Thanks in advance.
Thanks in advance.
