Trying to take off the discs to get at the wheel bearing. What is the size of the bolt that sits right in the middle of the disc. I need to order one from halfords or should I go to nissan??
IIRC, its 32mm. You will need an impact spocket, you will burst a STD one..
Disclaimer
If the size is wrong, sorry, its a 36
i've used the halfords professional deep normal sockets and never burst one yet.....but there's always a first time! cost about 7 quid.
the nut should be about 250Nm and i usually find if you have the footbrake applied and use a long breaker bar it's easy to undo.
Ian
