1 - 6 of 6 Posts
Hi guys,
Bit of a double whammy here, the car came with an AP black bbk set up and the pads are needing changing. Currently has ds2500's which are very dusty. Can anyone recommend a decent pad for fast road use only?
Also this is my current tyre set up which came on the car
Front 285/35/20
Rear 305/30/20
Tyres are p zeros all round. I've looked on here but can't get confirmed if this is an ok combo. AC speedtech posted sonething about the torque split so went for a drive but it's beyond me what I'm looking for.
Help appreciated
Chris
AP BBK Pads - JCR Does some nice pad upgrades for this, but DS2500s are a good road pad.
285/305 combo comes out at 2.39% which is too high, anything less than 1% difference or as close as possible to the OEM sizes is better on the 4wd clutch.
Hi guys,
Front 285/35/20
Rear 305/30/20
Help appreciated
Chris
Hi,DS2500s are dusty pads,try MX72s they are a good pad,with a lot less dust,might be a harder pad though,so not quite the feel through the pedal,ive been running 285 front and 305 back mpss for 3 years now with no side effects.A lot of people on this forum do i believe.
Discussion Starter #4
Hi guys,
Front 285/35/20
Rear 305/30/20
Help appreciated
Chris
Ill def take a look at them ***x1f44d;
Can I ask why you opted for that set up, what make do you use? one of my fronts will need replacing soon aswell. T/C light flickered once when I booted it, other than that and a bit of judder last night scaring the life out of a friend at silly speed they seem an ok tyre
Cheers mate, I'll give them a shout. Yeah that's what AC where eluding to in an old post. Can the 305 remain but the fronts be changed? It's the front passenger needing changed and the backs are like new
Tried to take in posts from here earlier but tyres aren't really something I've looked into when past modding. Different story now with this car
Speak to AC Speedtech to order you a set of Motek Racing ST600 pads for fast road and track use. Andy or Alan will tell you more about the info.
1 - 6 of 6 Posts
