Right just a quick one,
I have just tested my Panasport G7`s on the R32 today and to say that there is minimal clearance between the alloy and the brake callipers (I have an R34 set up) is an understatement :chuckle:
There is about half a *** paper clearance when the wheel rotates!! I was going to make up a set of spacers of about 3mm, so I have about about 3.5mm clearance.
Does anyone see any issues with this?
Think Newera sell some 4mm or 5mm spacers.
I have about 10mm clearance on my fronts I got some 10mm hubcentric H&R spacers to help clear my calipers.
Think you defo need some spacers by the sounds of it. But make sure your wheel studs are long enough to take them if you do too!
bob
Yer the thread engagement was the main concern.
If I go with a 3mm spacer (will make my own at work as they cost next to nothing to lasercut and machine etc) then I will have about 3.5mm clearance and still have about 1 diameters worth of thread engagement, which should do the job still.
Just out of interest is it easy to install longer studs? Forgot to look last night
