so before people reply "SEARCH!" - read my question....
car in question is a GTR, ergo the requirement for same wheel & tire specs front to rear.
however, if you were to fit staggered wheels, but with the same offset and tire size, would the same rules apply, or would it be ok??
as an example, front 9" wheel at +22 offset, rear 10" wheel, +22 offset. So the inner rim of the rear wheel will be 13mm further inboard, and the outer lip of the rim will be 13mm further outboard! If the same size tires are fitted, the tire will still be centered over the CL of the hub, no difference to diameter or circumference, therefore should not cause issues with ATTESSA etc. and therefore no impact to handling.
discuss.
discuss.
