when only need to change the Actuator and the wastegate of the turbo?
i m still using stock turbo, do i need to change this 2 things?
You can't do anything to the wastegate on a std turbo because it is internal, but you can put uprated actuators on there if they're N1's or R34 items. Otherwise you'll just blow your turbine wheels off by overboosting them ceramic things ;)
PS; Don't go over 1.1 bar on the std r34 ones and the N1 about the same.
